Low slope roof (2/12) in Colorado w/ridge vent
![](https://secure.gravatar.com/avatar/516e0e84330ef7c91c0d9b02bd7dac65?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Appreciate comments from all & Martin Holiday,
I’ve got an old remodel with a T&G roof deck.
Below the T&G will also be SIGA Majrex then drywall. https://www.siga.swiss/us_en/catalog/majrex
On top of the T&G will sit 11 7/8 I-Joist that packed with Fiberglass Insulation. On top of this will be SIGA Majcoat (a one way vapor membrane). https://www.siga.swiss/global_en/catalog/majcoat/majcoat-majcoat-sob
Then a 2-inch air gap (2×4 sleepers) followed by decking and TPO roof.
— See Attached Drawings —
At the ridge line will be a vent
http://www.airvent.com/index.php/products/exhaust-vents/ridge-vents/continuous-ridge-vent#description
I’m concerned about the low slop roof and the possibility of snow build up or wind entraining rain water into the ridge line vent.
Opinions or Comments?
MCMB,
Infiltration at the ridge may well pose a problem, but the larger one is that low-slope roofs don't have sufficient pitch to move air through their ventilation channels.
https://www.greenbuildingadvisor.com/article/insulating-low-slope-residential-roofs
You are much better off designing an unvented assembly.
