Low EMF electric stoves, water heaters, and dryers?
![](https://secure.gravatar.com/avatar/6ddc147fa6b765b451109243f699b02b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
user-5378275
Trying to find low EMF dryer, stove, and hot water heater. Is there a difference or are they all close to the same? Thanks, ben
Ben,
I don't know of any appliances that fit what you are looking for. But there is plenty of evidence that you don't have to worry about electromagnetic fields. For more information, see EMFs and Human Health.
thanks martin, one thing i really like about electric in general is the possibility of cleaner fuel. do you have any advice on good efficient stove, dryer and hot water heater the are inexpensive? thanks again and happy martin holladays to you
Ben,
Electric appliances that produce heat using electric resistance elements (that's a description that applies to almost all electric kitchen ranges, electric clothes dryers, and electric water heaters) all have the same efficiency. They are 100% efficient.
Performance improvements can be achieved by adding extra insulation (in the case of water heaters and electric-resistance ovens), but that's about it.
If you want a more efficient appliance, you have to consider a different technology -- for example, an induction range, a heat-pump clothes dryer, or a heat-pump water heater. But if you are looking for an "inexpensive" appliance, as you are, you are stuck with the conventional electric resistance approach -- and all of those appliances have exactly the same efficiency.
thanks again martin, btw looking thru your site i found some disconcerting stuff on offgassing ovens, is there an electric oven that is less toxic as far coatings and such?
