Slab Insulation for Garage with Radiant Floor Heat
![](https://secure.gravatar.com/avatar/5b9d5a432b21cb8b8f724a801bec11a1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I started construction of our home in climate zone 6. The basement slab will have r10 sub slab insulation with pex within the slab. I would like to heat the garage the same way. Is r10 sub slab enough? Should I put some rigid foam against the frost walls as well? If so how much? I’m open to ideas.
The walls will be about 10 ft wall, 2×6 with a vapor retarder and batts, r5 on the exterior. My footings are formed and walls will go in next week.
The advantages of PHP web software development are numerous https://mlsdev.com/blog/how-to-create-social-media-app. First of all, it is suitable for beginners. Secondly, it offers flexibility when it comes to data storage. Because of its extensive library of built-in functions, PHP code can be used to connect to any database, regardless of type. Furthermore, PHP code has been around for over a quarter century, so its main bugs have been worked out. This makes PHP more secure and trusted by developers. Consequently, many frameworks have been created for PHP web software development.
Determining whether R-10 insulation under the slab is sufficient to heat a garage depends on several factors, including the climate in your area, the desired temperature in the garage, the size and construction of the garage, and the heating system being used.
R-10 insulation is relatively low in terms of thermal resistance. While it can provide some insulation value, it may not be sufficient on its own to maintain a comfortable temperature in the garage, especially in colder climates. [Vampire Survivors](https://vampire-survivors.io)
