Looking for a clear coating with reflective value for a copper roof?
GBA Editor | Posted in Energy Efficiency and Durability on
Copper roof is hot to touch is there a coating to help cut down cooling cost
  1. Riversong | | #1
    White paint.
  2. Riversong | | #2
    The reason copper gets hot in the sun is that it has a relatively high As/E ratio, or the ratio between solar Absorptivity and infra-red Emissivity (about 2.1).
    You can reduce its solar absorptivity with selective IR reflecting coatings, but I doubt you'll find a clear coating that won't change the appearance of the copper.
