Log-in problem
![](https://secure.gravatar.com/avatar/fa6a45bc6929620c233f8629c6430692?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I signed up for the GBA Prime service this morning. However, when I try to read the restricted articles, the pop-up for registering comes up but does not respond to the “Already Registered? Sign In” prompt.
So I can’t sign in. Please help.
Mike Guthrie
Mike,
I'm sorry to hear about your problem.
The first place step if you need help with this type of problem is to contact our Customer Service Department. Here is the email address:
[email protected]
If the customer service people can't solve your problem, you should let me know (although I really don't know how to fix this type of problem). My email address is:
martin [at] greenbuildingadvisor [dot] com
-- Martin Holladay
Don't feel like the Lone Ranger Michael. Happening to me as well right now! Same exact thing!
Chris,
Did you figure it out yet? If not, please email me and I'll try to help. My email address is:
Got it.
Thanks Martin!
Seeing how no one left a solution, I will comment on my solution to this issue. It was due to an extension I was using. In my case it was ClearURLs. I have never had an issue with this extension in the past, but obviously it interferes with how greenbuildingadvisor does its login.
Go through your extensions and disable them one by one until you can log in. Or use whatever your browser's version of private mode is (assuming you don't allow extensions in private mode).
The error I was getting was "Your credentials are invalid" or something like that. Very confusing.
