Location recommendations for minisplit heads
![](https://secure.gravatar.com/avatar/d113967f3b26390a139d732628e3621a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I know it’s been asked many times, but would appreciate suggestions on locating the head units for two minisplits in my ‘pretty good house’. I have attached the floorplan. Some things to note on the house:
– Climate Zone 6b, southcentral Montana
– majority of windows are on the east side for the river view
– windows and doors are double-pane. South windows are high SGHC for solar gain
– first floor concrete slab
– underslab = R20, walls = R40, roof = R60, windows = R4
The intention is to have one unit on the first floor to provide the majority of heating and another on the second floor to provide cooling. I will likely go with the Fujitsu cold weather units.
I have strongly considered a floor-mount unit on the first floor, perhaps along the NE or SE corners to direct heat along the east wall, but not sure how to drain condensation with a floor mount and slab. Any ideas on that? The second floor would be a wall mount, near the ceiling.
many thanks, all
Brian,
If your upstairs ceiling is high enough, and your closet door is low enough, perhaps you can mount the second floor unit above the closet door.
Thanks Martin,
Those locations are what I was thinking as well. The second floor ceiling is standard 96" finish height below the 2x4 ceiling chase, so there should be around 14-15" above the closet door. This should be just enough as the head unit is ~12" high. Do you have any ideas on dealing with condensation in a floor mount unit on the first floor slab or is not an issue if it's only used for heating?
Brian,
The lineset of the floor-mounted indoor unit (refrigeration tubing and condensation piping) exits through the wall at the rear of the unit above the slab. The illustration below is for a floor-mounted Mitsubishi unit.
More info here:
http://meus1.mylinkdrive.com/files/MFZ-KJ09-18NA-U1_Installation_JG79Y071H02_02-16.pdf
