Liquid flashing advice
![](https://secure.gravatar.com/avatar/c4187f35be233f48e33f5288b33bfbe4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
I want to seal the joint between framing and foundation in my new barn build. Since I’m using Henry Blueskin as my WRB I think I’ll stick with Henry products. There’s some used Henry Air Bloc LF for sale on ebay with a manufacture date of 03/21. The spec sheet says it should be good for a year. Any opinions on using recently expired liquid flashing?
If there was some flashing that had been sitting in a climate controlled warehouse and it was a lot cheaper and it was just a barn - I might go for it. OTOH, if this stuff sat outside in the sun on a jobsite all summer, I'd be less keen.
Thanks Canada. That's pretty much where I am. It is a lot cheaper and the application is not mission critical. I just don't know how it was stored and am assuming the worst. I just wonder what happens after a year and after being stored in less than ideal conditions. Less sticky? Cures in the sausage tube?
Have you ever tried a really old tube of caulk? Sometimes they are almost fully cured inside the tube.
Yup. Good point
