Liquid applied air / moisture barrier application
![](https://secure.gravatar.com/avatar/796f67237b74bd7123706c570aa56a4a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
We typically use 2 layers of building wrap for stucco wall finish.
If we use liquid applied barrier, do we need 2 coats of it or what are the guidelines in using liquid applied air/moisture barrier on stucco?
Raymond,
You should obviously follow the installation instructions provided by the manufacturer of the liquid-applied WRB. But I would install a layer of building wrap over the liquid-applied stucco, at a minimum, for a stucco application -- and ideally, I would find a way to include an air gap between the stucco and the WRB. For more information, see To Install Stucco Right, Include an Air Gap.
