Lined masonry chimney vs an insulated stainless steel chimney
![](https://secure.gravatar.com/avatar/d0262569bf6a8b7d62445909aa7ca5a6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
This would be a single flue chimney that would just serve the wood stove/ and or eventually the masonry heater. What are the plus/minuses of both and the realistic life span of them? Our primary source of heat will be wood.
Philip,
I used to be a firm believer in masonry chimneys lined with clay flue tiles; I have two stone chimneys in my own house. However, masonry chimneys represent a significant thermal bridge; these chimneys can leak a lot of heat, and are more likely to lead to ice dams than metal chimneys.
I think that the era of the metal chimney has arrived, and it's time to bid adieu to brick chimneys and stone chimneys.
