Clearance in front of minisplit
![](https://secure.gravatar.com/avatar/88e819fc6c60b1d1fbfbd31d2900f0c3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
I am interested installing a LG Multi F mini split system with a low wall console indoor unit (LQN090HV4). https://lghvac.com/resource-service?filename=EM_MultiF_IDU.pdf The installation instructions have required clearances on the top, bottom and sides of the unit. I don’t see any clearance for the front of the unit.
Is there a required clearance for the front of the unit? I’m considering installing it behind a piece of furniture that would block the front of the unit but I don’t want to obstruct the airflow.
Thank you
greg
Greg,
Have you called LG's technical support line? I think that is your best option for receiving clarification on this issue.
