Lennox Signature Heat Pump solution – looking for experiences
![](https://secure.gravatar.com/avatar/7430df41c37bb762edbb58f06e07d875?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Greetings,
We are in the process of building a new home and we have been getting estimates for HVAC.
In addition to a Mitsubishi/Zehnder solution I’ve also received a proposal using Lennox equipment for our high performance home.
I’m curious if anyone has experience with the David Lennox Signature series in a situation like ours. We are in climate zone 6B.
The system is a combination of SL25XPV heat pumps, CBA38MV air handlers, and the associated ERV.
I usually see the Mitsubishi/Zehnder combination being used in high performance homes that I have read about online, however I’m hoping others may be able to share confidence, or lack there of, to consider the Lennox option.
Thank you!
