Leak path for tiny house condensation near wheel well
![](https://secure.gravatar.com/avatar/243ceacf9fbf018b29f21860e40b775d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I’ve been recommended to provide a drain path for any condensation that were to occur inside of a tiny house trailer subfloor, how do I provide a drip path without making too large of a whole in my metal flashing (bottom of the trailer) that would otherwise introduce air and potentially condensation problems because of air movement in the subfloor above the flashing? Do I just go air tight and make a mesh drain path somewhere near the wheel wells or do I make it all fully air tight and leave no path?
Michael,
This post might be helpful: https://www.greenbuildingadvisor.com/question/tiny-house-of-wheels-moisture
Look for duck bill drains. I've used them for industrial equipment, they do a good job of keeping most things out but allow for liquid water to drain out. Good for a place like a utility room where there bound to be water leaks.
You could also create a diffusion port on the bottom out of a bit of sturdy housewrap or permeable peel and stick. You can install it over a couple of strategically located perforated metal panels in the floor.
