Layering 1/2″ EPS Foam Under Concrete Slab
![](https://secure.gravatar.com/avatar/4bbd8574a6506ae49de2e3714f6fcf98?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Hi All I’m new here and working on a single story 500SF ADU in the side yard in Mississippi (Zone 3A). I have never done insulation under a concrete slab and a foam manufacturer in the area has a bounty of 1/2″ Type VIII (1lb/ft) EPS sheets available at discount.
My question is basically can I stagger and stack 4 layers of 1/2″ foam to achieve the 2″ thickness I would like. From what I’ve read minor gaps/imperfections in the foam under a slab shouldn’t negatively effect things, so I am inclined to use the 1/2″ discounted foam.
Any input welcome. I will be using 4″ compacted gravel below foam and a vapor barrier above foam and below concrete.
dan2020,
No reason not to I can think of.
Thanks for the input Malcolm. Much appreciated.
