Kraft paper with flash and batt
![](https://secure.gravatar.com/avatar/aefee5d4096d1053b74844d001b6d230?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I live in Virginia and I have a minimum of one inch of foam board plus spray foam in my old 2×4 walls and am about to install the fiberglass insulation. I bought R-13 insulation with Kraft paper. Should I take the kraft paper off when installing the insulation?
Duane
Duane,
You can leave it on or take it off -- either way will work fine.
