Kraft faced insulation
![](https://secure.gravatar.com/avatar/5c208b912a8db9dfff9c5361361a0d1d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
My hardware store only stocks kraft faced batts. Everything I read says because of challenges with insulation the kraft face will never be affective.
So why sell it with the kraft attached? Anytime I see insulation done by a company they are using unfaced batts.
And if the kraft face works then why do people then use poly sheeting.
None of it makes a lot of sense to me.
joenorm,
I don't know the answer to your first question, but (for better or worse) people use poly primarily because it is a combined air and vapour-barrier. Faced batts would never be an effective substitute to use for air-sealing.
