kneewall: fiberglass batts with foam boards
![](https://secure.gravatar.com/avatar/fc384e4b1563271575db78024e8bdb14?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fq.png&r=g)
Hello,
Ive been seeing videos on kneewall insulation and they all seem to have fiberglass batts in the wall and then sealed up with a foil lined foam board on the outside. Wouldn’t this cause moisture issues with faced bats in the wall and foil facing out?
When I moved into my cape cod a few years ago it had insulation on the roof/floor/walls and they stapled a giant plastic sheet against the wall covering the fiberglass. I removed the roof insulation and plastic sheeting. Am I supposed to have a wind barrier?
