Is a vapor barrier needed in a floor over a garage?
![](https://secure.gravatar.com/avatar/36977b2b0c2a6750fa8ab52e9b7699d9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Not sure if a vapor barrier is absolutely required for the floor of a room over an unheated garage.
Reference: https://www.greenbuildingadvisor.com/question/flooring-install-vapor-barrier-or-glue
Tony,
There are no code requirements for vapor barriers in floor assemblies. Nor are there any building scientists who recommend a vapor barrier in a floor assembly.
If you plan to install OSB or plywood subflooring, these materials will act as a vapor retarder.
In all cases, attention to airtightness is very important.
(By the way -- even though it doesn't matter in this case -- it's usually a good idea to tell us your climate zone whenever you ask a building science question.)
