Is this wall system adequate for Zone 6a — maritime climate?
GBA Editor | Posted in Energy Efficiency and Durability on
I would like to build a garage with 2″x6″x 10′ studs. From exterior to interior: 3/8″ ply siding, 3/8″ gap, Tyvek wrap, 1″ EPS board, 2″x6″ studs, 4″ EPS fitted between studs, 6-mil vapor barrier (called for by code), then drywall.
  1. GBA Editor
    Martin Holladay | | #1
    James,
    As far as I know, there is no code anywhere in the country that requires an interior 6-mil poly vapor barrier.
    Rather, the code requires a vapor retarder. Kraft facing or vapor-retarder paint can satisfy this requirement.
  2. James | | #2
    Martin,I should have stated I am in Canada.According to the building inspectors in Halifax,N.S.
    ,section 9:25:42 of code says 6mil.poly vapor barrier is standard. The question is "is this going to cause moisture issues."
  3. Riversong | | #3
    Probably.
  4. James | | #4
    Thank you for response.I will have to find another solution.
