Is there a reliable way of repairing a double pane window if the seal has broken?
![](https://secure.gravatar.com/avatar/f3b08552d989ab7a3d7f07b1d3986e14?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I have light gray spots appearing on the inside of the outer pane of a double pane sash window. They don’t look like drops of moisture. More like translucent round snowflakes. Each round spot is made up of concentric rings. Frankly, they look beautiful.
I moved to this condo three years ago. The windows are about 7 years old.
Unfortunately, there is no reliable way to repair a failed IGU.
Can you post a picture of what you are seeing in your glass?
Thanks
