Is there a humidity-controlled attic exhaust fan on the market?
![](https://secure.gravatar.com/avatar/5902a7c049ef94407b962bba5d6f9549?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Is there an exhaust attic fan readily available on the market that trips on in a mixed humid climate when the temperature gets hlgh enough to create attic humidity in a situation where soffit vents aren’t possible?
Don’t want to suck out air in the winter, only when we need to remove humidity. Thanks
Airvent makes a low-voltage thermostat for attic fans for under $40. I write this as our house is being cooled by a single fan while the outside temperature is almost 90. So, think about using that fan for more than just cooling your attic. Here's an article about our house I wrote for Old House Web and one in Mother Earth News about natural ventilation: http://www.oldhouseweb.com/blog/how-to-cool-your-house-without-air-conditioning/ - and this Mother Earth News article about 3 houses in the South that use no a/c - http://www.motherearthnews.com/blogs/blog.aspx?blogid=2147484239&tag=Greenovation%20TV
Rick - be aware that if you use a powered attic fan without soffit vents when A/C is running you will almost certainly be pulling that expensive conditioned air right out of the house. Matthe's strategy is fine but ONLY for homes where A/C is not use.
