Is there a foam insulation product safe for chemically sensitive persons?
![](https://secure.gravatar.com/avatar/e19128a9905ac953b61027315d916f24?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I am in the process of building a home and am chemically sensitive. For insulation we are using a BIBs fiberglass system with 2×6 construction. We would like to seal out any cracks with some type of foam but I don’t want to have PBDE’s or chlorinated flame retardants if possible.
I doubt that you will find any spray foam that does not have some toxicity. Even the latex spray foams use petrochemical propellants.
You may have to use a good quality latex caulk, but I would suggest checking the MSDS for any product.
