Is the R-value of a PVC ceiling better than 6.4 mm RhinoBoard?
![](https://secure.gravatar.com/avatar/568c0a8fe218c0cdfb9eb268528fec15?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
johanvanvuuren
| Posted in Energy Efficiency and Durability on
I need data on PVC ceilings’ R-value and the advantages of PVC ceilings over RhinoBoard.
Johan,
Neither RhinoBoard nor PVC ceiling panels have an appreciable R-value. These are not insulation products.
RhinoBoard is the brand name of a type of gypsum wallboard (plasterboard).
PVC ceiling tiles are like vinyl siding for your ceiling.
The R-value of either product is less than R-1. If you want your ceiling to be insulated, you will need to install some insulation -- for example, fiberglass, mineral wool, cellulose, expanded polystyrene, or polyisocyanurate.
