Is recycling 30 year old plywood a good thing?
user-1140356 | Posted in General Questions on
On my gut rehab and second story addition in New Jersey, I’m considering recycling the plywood from the roof. Is this a good idea?
  1. GBA Editor
    Martin Holladay | | #1
    Michael,
    What do you mean by "recycling"? Does that mean:
    (a) Leaving it right where it is?
    (b) Removing it and using it for another purpose like building concrete forms?
    (c) Delivering it to a recycling center where it can be ground into chips and used for other purposes?
  2. user-1140356 | | #2
    Martin,
    Thanks for responding. By recycling I mean using it as sheathing on new construction. The plywood is in okay shape and was carefully removed. Even so actually reusing it makes me nervous. I would probably use it on the new garage.
    Michael
  3. GBA Editor
    Martin Holladay | | #3
    Michael,
    Use your common sense. If the plywood seems dry and sound, with no soft spots or evidence of rot, I don't see any reason why it can't be reused.
  4. user-1140356 | | #4
    Thanks again Martin. I guess my common sense knows so little about how nailing patterns and stresses work on plywood sheathing, that I'm nervous trusting it.
  5. wjrobinson | | #5
    Michael, you... don't trust the plywood. You, should not use it. Build a shed with it or put it at the street marked "free" or sell it on Craigslist, though that site scares me far more than used plywood.
  6. user-1140356 | | #6
    Thank you both. We've decided to use it on the rake eaves, porch roof, and other spots we deem less demanding (there may be a shed or two as well).
