Is it safe to paint Polyisocyanurate Insulation?
![](https://secure.gravatar.com/avatar/d3429828c5c0fa6c1450624db61500ea?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I have a lot of Polyisocyanurate Insulation in my basement. We are not at a point where we can finish our basement, but I’d like to at least get it looking a little nicer so it can be used as a playroom – carpet on the floor, paint on the walls.
The top half of the walls is this Polyisocyanurate Insulation. It has a reflective aluminum facing.
Is it safe to paint this? Will it decrease the effectiveness of the insulation?
Thank you!
Unless it's a fire-rated type, leaving polyiso uncovered in a conditioned space (even an unfinished but used space) without a thermal barrier equivalent to half-inch wallboard is a code violation and a fire hazard (though the hazard isn't huge in most situations.)
The right thing to do is to put up a code-legal thermal barrier and paint the thermal barrier before using it as playroom. Depending on your climate and the R-value of the existing polyiso you may even want to put up a non-structural studwall insulated with unfaced batts as something to hold the thermal barrier. At a minimum 1x furring through-screwed to the foundation with TapCons 24" o.c. can be used as something to hang half-inch wallboard to serve as your paintable surface and thermal barrier.
