Is it possible to retrofit a unconditioned attic to a conditioned attic?
![](https://images.greenbuildingadvisor.com/app/uploads/2024/06/11224209/46424-avatar-1718160128-100x100.png)
Help Requested: Is it possible to retrofit an unconditioned attic to a conditioned attic?
If yes, what are the steps?
Project Details-
Climate Zone: 2
Home Built: 2017
Type: Production
Roof: Hip and Valley, 24” OC
Roof Radiant Barrier: Tech Shield
Attic Insulation: Loose Fill
Notes: Ridge Vent, AHU in attic
Thank you!
hvacMENSH,
- Choose a cathedral roof assembly. Here are five suggestions: https://www.greenbuildingadvisor.com/article/five-cathedral-ceilings-that-work
- Seal the eaves and ridge vents as necessary
- Remove the loose fill insulation on the attic floor
- Provide heat and de-humidification.
Thank you, Malcolm.
