Is it a good idea to vent a bath fan exhaust out of eyebrow roof?
![](https://secure.gravatar.com/avatar/278ed3b69f85e6f0c75af8758e24ed15?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I originally liked the idea of venting the bath fans out a gable end of the house in order to minimize roof penetrations on the steel roof. I did some research into venting through the main roof soffit vents, and obviously that is not a great idea due to the possibility of drawing moist air back into the roof.
However, I will be having a couple eyebrow roofs over the windows on the gable ends that seem like would be excellent spots to exhaust the bath fans. I originally intended to use non-vented soffit on these small roof sections, but perhaps I could use vented soffits here and dump the bath exhaust air into these?
Can you think of any implications or downsides to venting into / out-of an eyebrow roof?
Climate zone 5
Adam,
If you are routing the ducts to the gable walls, why not use normal wall terminations?
Bath exhaust ducts installed in soffits in cold climates can develop icicles. I would use a regular wall termination if I were you.
