Is anyone familiar with IndowWindows.com?
![](https://secure.gravatar.com/avatar/a2fad93dd7d731041315f59ccbd4a7b3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I’ve been thinking of ways to improve seal of single pane swing out windows. I don’t like the look or cost of new Windows.
I ran across these interior window pane thingies called Indows.
Any thoughts or experience with them?
It's a sheet of plexiglas with a compression fitting that you install in your window frame as an interior storm.
It should work okay, but at $30 to almost $40 ft², there may be more cost effective alternatives.
I have lots of plexiglass panels that are about 1” too big all around and no way to trim it to size or to apply compression fitting.
I checked into it, but the insets were almost as costly as a new replacement window.
I tried these. A lot cheaper but not plexiglass. They’re made of acrylic on aluminum frame.
https://www.windowinserts.com
Deleted
