Is a vapor retarder necessary on ceiling/attic interfaces of unconditioned attics when using blown in cellulose or fiberglass insulation?
![](https://secure.gravatar.com/avatar/f9c9c55976816c7510bd5ba462298d8e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hi,
I’ll start this out by saying I might be overthinking this …….
My goal is to prevent condensation on the plywood sheathing of our unconditioned attic that could result in attic mold growth – especially during heating season during our cold climate zone 5 winters where temperatures can get as low as 0 degrees Fahrenheit at times.
Question: Is a vapor retarder needed on ceiling/unconditioned attic interfaces when using blown in cellulose or fiberglass insulation of sufficient R value; and if this is the case, is latex paint sufficient (assuming all of the other areas for air leaks have been air sealed?)
Thank you for your time.
mclola,
https://www.greenbuildingadvisor.com/question/vented-attic-vapor-retarder
Thank you for this link/information, Malcolm.
