Is 2” EPS or XPS Styrofoam Totally Impermeable to Radon?
potton | Posted in General Questions on
In itself is styrofoam impermeable to radon?
  1. Andrew_C | | #1
    No. Normally if you're using foam insulation under the floor, you cover it with a layer of plastic sheeting, and that is the barrier that prevents radon gas from coming up.
