Inward Vapour Drive – Cold/Temperate Rainy Climate
Normal
0
21
false
false
false
PT
X-NONE
X-NONE
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:”Tabela normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:””;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin-top:0cm;
mso-para-margin-right:0cm;
mso-para-margin-bottom:8.0pt;
mso-para-margin-left:0cm;
line-height:107%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:”Calibri”,sans-serif;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:”Times New Roman”;
mso-bidi-theme-font:minor-bidi;
mso-font-kerning:1.0pt;
mso-ligatures:standardcontextual;
mso-fareast-language:EN-US;}
Hello all,
I was wondering how concerning is inward vapour drive in a cold/temperature cloudy and rainy climate.
The Wall I have in mind is comprised by brick, 2´´ unventilated air cavity and steel framed wall. The steel framed wall is the following:
– External 4´´ rockwool insulation
– Cement board sheathing
– 4.7´´ Rockwool batt insulation
– 2 layers of gypsum plasterboard
– Possibly vapour open painting on the interior
I obviously have a reservoir cladding (brick) which will see a lot of rain water. However, in this climate, 90% of the day is cloudy and practically no indoor cooling is used. On top of that I will not have a vapour barrier on the inside.
Although I acknowledge that having a reservoir cladding, coupled with a non-vented cavity and vapour open assembly can be risky. Is really that risky when the inward vapour drive forces/ diffusion (solar radiation, cooled interior) is low and there is no vapor barrier on the inside? Is this a risky wall assembly?
Thank you in advance
CP
