Interesting design challenge: hot yoga studio building assembly
![](https://secure.gravatar.com/avatar/2b69fc037dd19a9f5f5e9fb53bbe4f7a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
An interesting question came up today. I’ve encountered a project where there is to be a hot yoga studio (conditions are 106 degrees and 50% RH) built into an existing CMU structure. Climate is mixed dry– Central California.
The psychrometrics are interesting– dewpoint is ~84 degrees.
Curious as to opinions on interior insulation to deal with thermal and vapor drive. This is just a hypothetical that was an interesting building science design case outside of the normal conditions for this audience.
I would go with all foil faced polyiso with seams taped, including the inside corners (I'd insulate the ceiling too). Probably some high density EPS under a subfloor for the floor if that needs to be insulted too. Maybe some cedar board and batten as a finished interior, or other "Sauna-style" material and design.
As a funny alternative though: perhaps skip the insulation altogether. Don't even bother building the studio. Just become a roofer and work summers in a humid location ;-)
Great ideas Bill!
I like the roofer idea too!! Roofer yoga-- maybe even throw in a goat too!
