Insulation under brick veneer installed over steel framing
![](https://secure.gravatar.com/avatar/c7ab0b3dbb2ff9bae2ab700dfd7c2490?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
kgva
| Posted in Green Building Techniques on
What is the best way to insulate a steel framed wall which will be brick veneered?
Continuous insulation between the steel studs and the brick is critical to getting any thermal performance out of it.
Steel is about 375x as thermally conductive as wood, which takes a huge toll on the performance of cavity-fill. After thermal bridging a 2x4 wall with studs 16" o.c. with R15 rock wool comes in at about R10 after thermal bridging, but the same wall stud-for-stud with steel framing comes in a bit under R7. With R13s it's under R6.
http://web.ornl.gov/sci/roofs+walls/research/detailed_papers/thermal_frame/
Raymond,
Just so there is no misunderstanding: when Dana wrote "between the steel studs," he didn't mean that the insulation should be installed in the stud bays. He meant that you need to install a continuous layer of rigid foam insulation, entirely on the exterior side of the steel framing.
If you are aiming for R-20 walls, you will need 5 inches of EPS, 4 inches of XPS, or about 3 inches of polyiso. More is better.
