Insulation strategy with Open Web Trusses
![](https://secure.gravatar.com/avatar/5e2271baf9ef3bc22b02fc07638db154?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
Hi everyone,
I’m working on a new construction house in California (CZ5) in the mountains where snow is also a factor.
Originally I had proposed a roof assembly (see first photo) with R-38 Comfortbatt Rockwool in the cavity and and 6″ of Rockwool Comfortboard (R-24) on top of the roof deck.
Now the structural engineer wants to change to 18″ D open web trusses (see second photo) and I’m a little stumped about what to do with the insulation strategy. I don’t want to fill the whole 18″ cavity with insulation and have my proportion of rigid insulation be totally out of whack. But I think the open web design will make it a challenge to keep the insulation tight to the sheathing. The owner also wants to avoid spray foam if possible, although if we need to I’m sure I could convince him.
Not sure if I’m thinking about everything correctly. Appreciate any advice. Thanks!
Leah
Leah,
If you go with parallel chord trusses you can use a vented roof assembly and eliminate the costly and complex above sheathing rigid insulation.
See assembly #1 in this link:
Hey Malcom,
Thanks! I've been getting pretty far in the weeds learning about all the advantages of exterior rigid insulation that I failed to see this more simple option. Thank you!
