Insulation seasonal room
I have a outside deck that I recently enclosed. The deck has a fiberglass surface, which is now my roof ceiling. I poured a concrete floor and installed radiant tubing to attach to existing home system.
How should I insulate? Do I need to install baffles in ceiling, before insulating, or can do without. My house is spray foam and no baffles were used. I am not doing spray because to small for contractors to come out.
Any ideas
Joe,
I can't tell from your description what kind of a ceiling assembly you are talking about. Are your rafters level or sloped?
It sounds like you want to build an insulated roof assembly. This article should answer your questions: How to Build an Insulated Cathedral Ceiling.
