Insulation Question
![](https://secure.gravatar.com/avatar/b0aaf92bf13f7e56f5900762f1674073?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I have 2 insulation companies. Quotes are similar and both are blown in borate treated cellulose. one uses 3 mil reinforced poly and the other uses the mesh webbing? what is the general feeling on these 2 methods? I have concern with breathability and was wondering what the Pro’s thought??
It is a small 20×30 structure that will also use 1.5 inch wood fiber insulation board on the walls as well as (2×6 walls and 2×10 rafters) blown in cellulose. I live in central Maine.
thanks Michael
I wouldn't use poly if you ever use AC. Consider MemBrain on the interior to limit moisture entering the wall.
I suspect the 3mil reinforced poly isn't a great choice, but I would ask the contractor why he uses it instead of netting/webbing (I wonder how long it will take 'insulweb' to go the way of 'kleenex' and 'google' and become a generic trademark). You might learn something interesting about how that contractor performs work.
The dense pack barriers I've seen used in order of frequency: insulweb, existing drywall (densepacking existing walls), and Pro Clima Intello.
