Insulation missing in space between first floor ceiling and second floor subfloor
We are adding a second floor addition to our one story house. We’re living in it while it’s happening so most of the ceiling is staying intact as they add new floor system above. The contractor laid subfloor without insulating the exterior walls (bands) between the first floor ceiling and second floor subfloor. We can cut back the subfloor in most areas but there’s a few places where it’s impossible. Is this problematic from a condensation point of view? Will the conditioned air in that space meet the exterior wall and create condensation and rot the exterior wall sheathing in those areas?
You don't say what climate you're in. But if you're not in a mild climate it's problematic from a building science perspective. That area needs to be insulated and air sealed. Condensation probably isn't a problem. Rim joists can be problematic if they are insulated but not air sealed.
Do you live in a place with code enforcement? The current International Residential Code would require that area to be insulated.
I’m in zone 3. Charlotte NC
