Insulating to the ridge
![](https://secure.gravatar.com/avatar/675d73deb42355324e6bc666f6116ded?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
SLAB – 3″ of rigid foam (R10) below the slab with 1″ rigid (R5) vertically along the perimeter.
WALLS – 2″ of rigid foam on the exterior of the sheathing and 5.5″ of mineral wool (R23) in the cavities.
ROOF – 6″ of closed-cell, spray foam (R42) on the underside of the roof decking.
Current Water/Vapor/Air Barrier Plan
SLAB – 10 mil poly taped and sealed at all penetrations and tied to the exterior walls. Note – still working on the tie-in detail since the floors throughout the home are set to be polished concrete.
WALLS – Tape and seal the rigid foam (with manufacturer recommended tape) at all junctions, the soffit, slab and all penetrations.
ROOF – Closed-cell, spray foam into the soffit and up to the ridge. Roof is likely to be standing seam metal.
QUESTION:
If I get the spray foam above code minimum for ceilings in Idaho (R30); are these plans sound?
I am shooting for R42 (about 6″ of closed-cell foam); do I need to go any higher/thicker with the spray foam?
Idahobuild,
Your plans sound good. A couple of suggestions you may want to consider:
- Taping the sheathing rather than the foam may be easier and make the transitions at the slab, openings and roof easier too.
- You may want to consider a hybrid approach to the roof which uses less foam.
Thanks.
(image added)
We'll be using trusses so, I'm not sure the hybrid approach would work as it looks like the change requires a cathedral ceiling. Our roof will be trussed and I am asking the installer to spray around the truss. I guess I'll lose some R-value at these locations since wood has a R-value closer to 1 per inch. But I'm hoping to make up for that with a good tight air seal.
Does that make sense?
