Insulating the floor of a house on piers
![](https://secure.gravatar.com/avatar/24e8f05ed1da58d86b2c82f33dace667?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Here in south Louisiana & Mississippi we have a lot of homes that are raised on piers, typically 1-3 ft. It would be nice to insulate the floor from underneath, but there seems to be no good way of doing it.
I am working on a project now where we’ve taken up the floor, and I would like to install some kind of 4’x8′ sheathing underneath the floor joists so that i could then spray closed -cell from above. Is there a product out there that isn’t flammable or doesn’t cost too much that would work? A well meaning friend suggested stapling Tyvek under the joists, but I don’t think that would hold it.
Any ideas?
Roger,
Lots of products are flammable, including plywood, floor joists, and spray foam. But at long as your spray foam is protected by 1/2-in. plywood, your building inspector should be happy.
In your climate, you should choose an insulation that isn't vapor permeable. The two best options are closed-cell spray polyurethane foam -- I think it makes more sense to spray it from below, aiming for the subfloor -- or foil-faced rigid polyisocyanurate foam, attached across the underside of the floor joists in an airtight manner and protected from abuse by a layer of plywood.
Thanks for your input, but wrestling plywood on my back in a 2' crawlspace doesn't appeal to my sense of cosmology or sciatia. Seeing how the joists are16 o.c. & solid bridging at every 4',making the "bays" approx15 1/2' x 46 1/2', maybe I could attach metal stud guards at each end from underneath, about 2' in from the bridging and lay in some 1" rigid foam, caulk it & then spray. I tried spaying from underneath once & I almost became a mummy.
