Insulating over an open porch?
![](https://secure.gravatar.com/avatar/69e0cbbd98d1bf31e1f57b4126801fe5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
I have a client building an 12×16 addition to an existing house. The addition will include an open porch/patio which is covered by trusses that span from outside edge of addition to outside edge of porch/patio. The question is this: is it better/cheaper to just insulate & seal the entire attic space between trusses or to create a wall between trusses that separates space above living space & space above porch – and thus only insulating this wall and the attic floor?
Timothy,
It hardly matters where the insulation goes, as long as the insulation is continuous around your conditioned space.
A far more important question is: Are you sure you have a continuous air barrier around your conditioned space? This type of porch / attic connection is a notorious example that often results in an interruption of the air barrier.
Know what materials form your air barrier; be sure it is continuous where your insulated wall meets your insulated ceiling; and check the details at the wall / ceiling junction.
