Insulating exterior electrical box from inside
![](https://secure.gravatar.com/avatar/33cf5e7e531efd85f980291370897d5c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
In my laundry room wall is the electrical box for one of my exterior lights. That wall cavity is open and I would like to insulate it from the inside. Getting it from the outside is difficult for me because of obstacles.
Jakeny,
You may not gain much by insulating a single electrical box, but you can certain air seal it using caulk or low-expansion foam.
Jake,
If your stud bay is open, the usual rules apply: Caulk any obvious air leaks (including leaks through the back of the electrical box), and then install insulation in the stud bay.
