Insulating ducts
I’m looking to insulate the ducts in my crawlspace to R8.0.
At my local Lowe’s and Home Depot, I don’t really see any insulation sleeves – only one or two stores carry these sleeves and not with the R-value I want.
I’ve heard that the inner diameter of flex duct is slightly larger than galvanized duct and can be used to insulate rigid duct. Is this true? If so is it a good idea?
I live in Dayton, OH. I’ve looked for an HVAC supply store, but google hasn’t turned up much that looks promising. I’m a newbie, sorry for any unclear nomenclature or misunderstandings. Thanks for any help,
Jacob,
I think what you want to ask for is duct insulation (sometimes called duct wrap), not "insulation sleeves."
Owens Corning makes R-8 duct wrap:
http://insulation.owenscorning.com/assets/0/428/429/440/663a338c-6f54-4132-bbb9-bcfd5737952c.pdf
If this product isn't stocked at Home Depot or Lowe's, perhaps they can order it for you.
Hi Martin,
Thanks for the answer, but I mean insulation sleeve. As seen here: http://www.handymanhowto.com/insulate-round-sheet-metal-air-duct/
To me it makes sense that they can make a sleeve for flex duct why not for rigid duct? I like the idea that there are much fewer/smaller joints and much less taping (probably less waste and less cutting too).
