Insulating bottom of radiant floor
![](https://secure.gravatar.com/avatar/070a85e08112758ecfe2d56b9faf8b80?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I have a radiant floor that was installed under my kitchen floor using the aluminium heat transfer plates. Below the kitchen is a semi finished, semi conditioned basement. I would like to insulate the floor to allow as much of the heat from the pex tubing to translate to the floor (rather than helping heat the basement). Is a radiant barrier (foil) with an airspace beneficial? does the insulation need to be installed airtight? Is fiberglass a good choice in this application? Any insight is appreciated!
Pete,
I suggest you read three previous threads on this issue, plus one article:
Heat Transfer Plates for Radiant heat under floor joists
Reflective barrier and insulation for radiant heat
What is the best method to insulate beneath PEX pipes installed under floor joists for radiant heat?
Lessons Learned the Hard Way
