Insulating Bathroom in 100-Year-Old House
![](https://secure.gravatar.com/avatar/9784678f6711511beefc053af81816ca?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hi
I am gutting the bathroom in a 100yo house in Canada.
From the inside here are the layers:
1. Plaster on wood lattes
2. 3/4 furring strips to hold the wood lattes
3. 3/4 wood planks nailed to the 2×4 framing
4. 2×4 framing (giving a 4 inch air gap)
5. Another layer of 3/4 planks nailed to the 2×4 framing
6. An approx 1 inch air gap
7. Brick
Note that the brick is there for cosmetic and protection reasons but is not structural.
I already removed the plaster and latte and would like to add insulation,if possible. I read that insulating older houses can be tricky.
What are your suggestions for insulation?
Thanks
A reader asked a similar question not long ago that prompted replies and links to related content that could inform your course of action: Air sealing and insulation for existing 100-year-old walls. You should read this Fine Homebuilding article too: New Insulation for Old Walls.
Thanks for your answer.
I think the link for "Air sealing and insulation for existing 100-year-old walls" is wrong though, as it comes back to this post.
