Insulating an interior garage wall
bets281 | Posted in General Questions on
Hello,  I have a 3 car garage and we framed a wall to close off the one car side (Heated and drywalled).   Craft faced insulation was installed to the heated side and covered in drywall.  Now we are insulating the 2 car side of the garage (will be heated also) and I am wondering if we can just put drywall over the interior wall insulation or should we use a vapor retarder (Aquabar B)? or is it not common to face both sides of an insulation batt, as the craft paper is already facing the one car side?  I am located in Ohio.   Thank you!
  1. user-2310254 | | #1
    How are you heating the garage? What steps have you taken to separate the garage from your living space?
    1. bets281 | | #2
      Sorry, I should have mentioned it is a detached garage. Heating with ventless gas heater
  2. Deleted | | #3
    Deleted
  3. user-2310254 | | #4
    Unvented heaters are dangerous, especially if the doors are closed. You really should use a vented shop heater.
    Do you have any long-term plans to air condition the space?
    1. bets281 | | #5
      We haven't decided for sure on the heater for the 2 car side. We've had the blue flame in the one car space for years and we just run it on low and its never been a problem. We do go check on it often and open the door to get stuff out etc..
