Insulating above slab
![](https://secure.gravatar.com/avatar/d77f1c18621d3ca623d6f3f1ee53a64c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hello,
I am currently adding R10 SilvrBoard – a high compression version above the slab. It will have two inches and then 2 layers of 1/2inch OSB on top of that.
Structural walls will go to cement. Non-load bearing will sit above – correct?
Question is about drain holes and what not in the mechanical room – do we just continue with placing down in the mechanical room and extend those up?
Thanks in advance,
Jarryd
Jarryd, as long as the concrete slab is flat, you can frame partition walls (non-load-bearing) on top of the foam. Higher density foam is even ok under load-bearing walls.
Yes, just extend your utility penetrations up far enough to make them accessible, and cut the foam around them.
