Insulating a thin log wall sauna
I have a sauna kit (thin log walls, 2 inches thick). It works pretty good but alot cooler in the winters since the log walls have little insulation obviously. Wondering what would be the best way to go about adding extra insulation. Vapor drive is a big concern in the sauna with a lot of hot steamy air. I always put another load of wood when I’m done to sort of “bake” the room dry. I haven’t noticed any mold or mildew in the structure.
I was thinking, Rockwool rigid insulation (comfort board) on the exterior. Then strapping and some sort of siding like a cheap T&G or board and batten. Hot moist air will no doubt get through the log walls but I’m hoping the comfortboard is vapor open enough to keep anything from mold and rot. Would that hot air make the rockwool offgas and put a smell or toxic air into the sauna?
Another option is Johns manville foil faced foam board (it’s rated for hot sauna temps) on the interior, then strapping, then T&G. I think this could also work but it would squeeze the interior space and require a redesign of all the benches.
Any insight on this would be much appreciated!
Here's a great article from Building Science Corp. about wine cellars, but if you scroll to the bottom it addresses sauna assemblies:
https://buildingscience.com/documents/insights/bsi-010-wine-cellars
That may be diving in more than you want to for this project, but it's worth a read.
If you didn't want to cut into the interior space, I think your rockwool + strapping/rainscreen + wood siding is a great alternative. It'll be pretty vapor- and air-permeable in both directions for whatever minimal moisture the interior should see (most wood-fired saunas I have been in are extremely dry, even when ladling steam onto rocks etc). Rockwool is essentially fireproof, since it's pretty much made of rocks - I don't think you'd have any trouble with it on the exterior and very high temps on the interior.
