Insulating a corrugated metal floor deck
![](https://secure.gravatar.com/avatar/af1677b5b37652015155b536981579d5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Hi –
I have a garage on a sloped waterfront lot in zone 6a (lots of moisture). The cement garage floor was poured on top of a corrugated metal floor deck held up with steel I beams. Under the main garage floor is a decent space that I’d like to finish and heat (unsure if I’ll ever heat the rest of the garage). Spray foaming the underside is one option I would assume but its costly. Would polyiso foil faced boards be an option if the seams were well taped or foamed?
Very much appreciate this forum and any feedback!
Todd,
Q. "Would polyiso foil faced boards be an option if the seams were well taped or foamed?"
A. Yes. If possible, the insulation layer should be continuous -- so that the ceiling insulation meets the wall insulation without any thermal bridges.
Don't forget that rigid foam needs to be protected with a layer of drywall for fire safety.
-- Martin Holladay
