Insulating a brick wall against a stairwell
![](https://secure.gravatar.com/avatar/0d2a42936e976ece8ef35e22da9a8958?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
We just finished gutting all plaster/lath on a 1905 brick apartment and I’m trying to figure out one insulation detail: The entry stairwell is directly against a brick wall and cannot be changed. I have about 1.25 inches of space to work with including wall covering, so not much can be done. The finish should be drywall and I’d like at least a small amount of insulation.
1)how to frame? wood furring strips mechanically fastened to the brick?
2)how to insulate? 1/2 inch foil faced polyiso with very careful detailing? spray foam?
Overall insulation plan if you are curious:
climate zone 4a
-4 inches of polyiso with staggered seams above flat roof sheathing (already done)
-dense pack cellulose or fiberglass on underside of roof deck between joists (12 inches). smart vapor barrier keeping it in.
-steel 1 5/8 inch studs offset 1 inch from the wall 1.5 – 2 inches of spray foam on all exterior walls all the way to the roof deck (except the stairs)
Tom,
It sounds as if your options are: (1) Rebuild the staircase, or (2) 1/2-inch polyiso and drywall, installed with adhesive.
