Installing rigid foam insulation with a French drain
![](https://secure.gravatar.com/avatar/755d14957eb0e05ffe3ec243287efbd6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello,
Another question about insulating my basement in Philadelphia. We recently had a French drain installed along one of the walls. The plumbers attached a dimple mat about six inches high at the bottom of the wall. Should I extend this to the top of the wall underneath the rigid foam board insulation I plan to install?
Also, there is not much room between the drain pipe and the wall–enough room only for a 1/2″ foam board (when I was planning to use 2″ foam board elsewhere). Should I use a thinner foam board for that wall for the sake of fitting it behind the pipe? Or should I use a thicker foam board but just cut it so it doesn’t go all the way behind the pipe?
