Installation of a firebox in a very old stone fireplace that is on an external stone wall and is very damp.
splice | Posted in Green Products and Materials on
Do I install a vapour barrier first and then rock wool or ceramic wool with aluminium foil in order to insulate the interior of the existing fireplace? would I use similar techniques to the techniques of shower construction e.g.. backboard etc?
  1. GBA Editor
    Martin Holladay | | #1
    Marina,
    Are you building a traditional firebox out of fire bricks and mortar? Or are you installing a manufactured sheet-metal firebox?
    If you are installing a manufactured component, you need to follow the instructions provided by the manufacturer.
